L.U. Cifer
- January 21, 2011
- Miami, FL
- '95 XLT
Truck turns over fine, but engine won't start until in cranks for a few seconds, and even then it's a "slow start" as if it's starving for fuel. If I turn the key "on" (but not so far to actually engage starter) I can hear the fuel pump. If I turn key on/off 2-4 times (I'm thinking to basically build up some fuel pressure in the system), the truck will fire up immediately upon engaging the starter. It seems like I'm losing fuel pressure when the engine is not running: is there a check valve of some sort in the fuel pump assembly that could be failed/failing? I changed the fuel filter hoping that was the problem; 'twas not. Truck runs great once started.
Am I correct in assuming this is a fuel pump problem? The pump is 21 years old so certainly not a surprise. Seems doubtful to me that this would be a problem with the fuel pump relay or the fuel "kill" switch that's supposed to shut down fuel flow after collision; agreed?
Assuming it is the fuel pump, what replacement brands should be avoided? Any reason(s) not to use non-Ford parts? Would love to put the Ford/Motorcraft unit back in there, but they are EXPENSIVE. My usual mechanic/shop quoted 2 hours on labor, so I'm satisfied with that. But, they quoted me $273 for FTG and $258 for Delphi parts, whereas I found significantly lower prices. I have not yet stopped by to see what the assemblies/kits quoted includes, but is it possible they include more "stuff" (e.g., hoses, clamps, etc.) that would make them that much more expensive than the replacement parts I found on rockauto.com?
Thanks!
Thanks!
