Is there a difference between 98 and 99 frames? | Page 2 | Ford Explorer Forums
Well, do you know what the difference is? And is it something that would be difficult to deal with?
Hokie~ i think that might help. I might not have to"notch" the lower airdam if it hangs down lower
Ok, I see what you are getting at. Sorry, the bumpers are different...the frames the same. You may have to cut out for access if the design changes imterfere with the mounting of the brush guard.
883 only fits 95-01 2nd gen, not 3rd gen sports and to be honest, they don't really work all that well.
BTW, the GG will fit 95-01 2nd gen, just the brackets change
I was just asking b/c he has a '97 My brushguard has nothing to do with the bumper when it comes to mounting. It mounts to the frame and to a frame horn bolt, but it just wraps around the bumper in the front
I like how we're basically chatting here ;)
Ok, if the brackets change, and i order the gg for the 99-01, how do i make it fit on my 97?
you try those brackets and then if they don't work, get other brackets... hang on.. lemme crawl under my truck with a digi cam... back in 3 min
The brackets come with the gg.... How would I order different brackets?
Basically.... I need the Brushguard for the 99-01, and the brackets for the 95-98... and its should work, right?
So, another ?.... Will the brackets fit the gg? Or are all the grille guards pretty much the same
in theory its gunna work, the bumpers are about the same height relativley. look at my photo gallery there are pics from my front bar, same sh*t different day.
Maybe these will offer some insight...
I see the brackets, but im confused, I have nothing to compare them to. What am I looking for?
Ok, if the frame is the same, and the horns are the same.. then maybe the brackets will swap.. b/c as you can see, the lower brackets are mounted to the frame and to the back of the horn... not to the bumper
I am really confuses.. I have a few holes in my frame in the same spots, but I have no way of telling if they are the same or not
I know the Manik ONLY mounts to the frame.... so i guess its the same...
