Is there any way to read a check engine light? | Ford Explorer Forums
El Duque
Lake Hiawatha, NJ
2010 Eddie Bauer
A little background:
I bought a '99 XLT 4.0 4wd as a second vehicle from my boss, he crashed it about a year ago and blew the airbags. The cosmetic damage is actually pretty minor. So, he patched up the interior and drove it for a few months, then bought a new car and let the explorer sit.
I've been driving it for the last two days to see what kind of problems would pop up. The truck has 180,000 miles and still runs great. Obviously the airbag light is on, but today the CEL came on too. I was wondering if it could be something related to the airbags, or something else.
I know on some cars you can use a paper clip and stick it into the jumper, or just count the number of times a CEL blinks, I'm sure there are other methods.
I would just like to know because I have to get the car inspected this Friday and I don't have time to get it fixed (if it's a potentially large problem) and inspected in the same day. So if it's something I could fix ahead of time it would be great.
Thanks
Autozone & Advanced Auto will read them for free.
Some auto parts stores will let you use a "code reader" in their parking lot. They will show you how to use it. OR, you can buy a code reader.
Good luck and enjoy the Ex!!
Thanks for the replies, but since I only have a couple of days I don't know if I'll get a chance to make it to an auto-parts store.
I guess there's no way to check with the old paper clip and blinking light method?
thanks
thanks
I dont think so, never heard of such a thing with an Ex.
That works with OBDI (EEC-IV?) type vehicles (1991-1994 explorers). 1995 and up ford switched to OBD-II on the explorers and the only way to read the codes is with a code reader. Just have to plug it in to a port in the dashboard and they pop right up. 5 minute job.
Allright, I'll give it a shot. Thanks for the help guys!
it has nothing to do with the bags.
That is a separate system.
Are you contimplating buying it ?
If so do note that bags are very expensive.
That and you will need to look for hidden damage from the impact.
Incorrect. The 1995 also can self read codes.
Actually, I already bought it. It was only $500. If it passes inspection I won't even bother replacing them
This is correct. 95 is still OBDI. It has an OBDII diagnostic port but it obviously doesn't work....
LOL- I use my custom jumper wire that I keep in my glove box for quick reads on the run!
I cant imagine it passing with out air bags
either way not a safe descision.
