Is this the amp I need? Newb to the audio stuff. | Page 2 | Ford Explorer Forums
It'l work, i just found the cheapest 4 gauge wire kit i could find, bought two, one for power, one for ground. Wire is wire..
The amp power kit I have uses 8 gauge for both power and ground. What is good gauge wire? 4-6?
for that sub you'l be fine with 8 gauge. Don't go crazy on a $20 speaker :p
plus if you already have the kit don't bother upgrading until you've tried it :)
Also, the Best advice i was ever given, you will get the best sound out of a speaker if you match the amplifier with the power handling of that speaker. So don't go crazy on an amp.
(PS: That jensen should be fine)
Yeah. That's why I wanna get a 500wt amp.
That works, make sure you always check RMS ratings though :)
What should I be looking for in RMS for a 400 watt sub?
Judging by the amp they provided in the regular package, probably 160-200rms... its hard to say when they dont mention the rms rating for that sub. The fusion amp with that is 180rms, but its probably over-rated.
you get what you pay for.
cheap "4 gauge" kits are really only 8 gauge wire with a thick jacket
I see that your EXP is an XLT. So I was wondering does it have the factory JBL system. (Unsure if it was offered in the XLT package) If it does you could possibly use the SUB amp. I did this for a while until I did a full sound system upgrade and was quite suprised at its output.
Never really heard that before, but after inspecting some cheap eBay kits I bought in the past, that is definately true
welding wire works perfectly fine...for my next install I'm using 0 gauge welding wire all around
No it didn't. At least not when I got it.
