kendrellh
- August 3, 2016
- gretna, la
- 97 explorer
Hi, im kendrell sort of new well about two weeks in with this forum and its been very helpful so far with the things i been addressing with my 97 explorer, i had a problem with my truck stalling, and did a smoke test before and after i change the hoses, lines, and other parts (iac,egr senor,tps,clean maf sensor, fuel pump including sending unit, fuel filter on the line, coil pack, wires, and plugs) plus other sensors i dont remember the name to. It starts up and idles great around 750, while its semi cool i can drive perfect but the warmer it gets it starts to shut off, like something is tripping and making the engine choke and cut off when i left my foot off the gas, between the local mechanic and this forum with my initial tread ppl or tellig me it might be a security issue, also my last code it threw was for the tps not responding with the mass air flow sensor thats why i changed the tps and clean the maf, and it said i needed to check the connection on the 02 sensors i changed a few months ago, but like i said my mechanic seems to think its something in the steering wheel because my linkage is off i think because when its in D its more to the left in 2, and i can pull my key out while its running so he thinks i need to change the whole column, which all the parts i change have been hit and miss i guess and still the same problem, has anybody heard of a security sensor or something in a truck this old that basically stock beside cc
