fatdad461
- June 10, 2006
- somerset kentucky
- 2002 xlt
A year ago, with the help of this forum, I diagnosed and replaced the shift solenoid. The vehicle is a 2002 Ford Explorer XLT with a 5R55W transmission. The reason for the replacement was very harsh shifting and a jerky vibration when moving. This fixed the problem and the vehicle ran fine after this was done. A year later, I am starting to feel a jerky vibration when the vehicle is in motion. This happens usually between 25 and 45 mph or I feel it when just coasting. It's like something is trying to shift or engage. The actual shifting between gears is smooth. After noticing this, I replaced the shift solenoid again. This hasn't fixed the problem. The only diagnostic code that is showing is P0401(EGR) - insufficient flow detected. Is there a possibility that this malfunction with the EGR is causing these symptoms? Is there another solenoid diode or chip that can cause this jerky vibration?
I appreciate any suggestions on what I should check next.
