jjay66
- November 28, 2006
- London
- 97 V6 SOHC
Hi there
I'm getting a judder at the tail end of braking. Pads OK. Was thinking poorly fitted discs.
Truck to big to fit on KwikFit's ramp (!) but without full brake inspection they say brakes OK. They suggested a suspension issue - wishbone bushes/rubber mounting on the prop shaft.
I am not mechanically inclined but the MOT the truck arrived with (Nov) states:
"offside front lower suspension arm has slight play in a ball joint"
Could this be causing the judder?
If so is it an expensive fix (cringe).
Hoping for a little advice before having the conversation with my mechanic,
Cheers
JJ
Cheers
JJ
