- November 6, 2000
- 2018 EX Sport Concept
I'm not real sure. The current master cylinder says Bendix on it so I don't think it's OEM. Could a seal blow in it? Autozone has a booster and master cylinder for $120. I may go that route since my current booster is quite rusty.
The original factory master cylinder is a Bendix. I bought a new Bendix MC and they are slightly different than the OE one, but still have the same connections and everything else.
I understood. Just not sure which one is suspect. It's puzzling because I would think with a firm pedal with no vacuum the hydraulic system would be ok. But a pedal that goes to the floor with vacuum and little braking force would point to either an internal or external fluid leak. As I said above nothing external. So fluid escaping around the piston(?) in the MC?
I'd only suspect the booster if there was no vacuum and zero braking ability after the engine has been turned off.
A pedal that goes to the floor with the engine running is a hydraulics issue, usually the master cylinder.
A pedal that goes to the floor with the engine not running is a vacuum issue, usually the brake booster.
When master cylinders 'go', very often it's just worn seals, o-rings, etc that is letting the fluid go by. It's possible to rebuild a MC with a kit, usually just with o-rings, springs, etc.
Came back home and pulled the check valve, it's good. I plugged the vac line and ran it around the block again. The pedal is obviously harder to push but still goes to the floor with minimal braking.
At this point I believe I ruled out the brake booster and am down to the master cylinder. Doesn't this sound correct? I'm really hoping as I can get one locally for $40+some fluid and have it back on the road again.
Is there a special way to replace the MC without getting air into the ABS pump? I really don't want to have to deal with that!
If the pedal goes to the floor with the engine running, it's the master cylinder.
Just be sure to use a good quality one. I would definitely not skimp on something as important as a MC. Not that a cheap one would be inherently dangerous, but it might not last very long. If you can get another Bendix, or something good for $40, go for it.
Standard bench bleeding before installation is the only thing I've seen for these, even in the factory service manuals. There's no special instructions for anything to do with the ABS. Just don't touch the brake pedal or get any air into the lines unnecessarily, bleed the brakes from shortest line (drivers front) to longest (passenger rear), then repeat the bleeding until you no longer get any air bubbles.
You should have a much improved braking system afterwards.
