strocket
- June 6, 2004
- San Antonio, TX
- 01 sport trac
I finally got everything up and running. im still keeping my eye on the fluid levels. Theyre still dropping so im assuming that the fluids circulating cause I dont have any leaks. My question is this, I have a flare every now and then. Its not all the time only when I give it alot of gas. I know that the computer has to relearn all of this shifts but I want to know if that flare is normal? For those that dont know I had to rebuild my trans. I burnt up the frictions in the overdrive drum. While I had everything taken apart I went ahead and installed the sonnax boost valve, sonnax end plug kit, and superior shift kit. Why is it still flaring from 2nd to 3rd? Could it have something to do with the fluid levels?? Or is it still something internal?? Any help is greatly appreciated.
