jenren81
- February 25, 2005
- Frisco, CO
- 03 Sport 4x4, 16 Tacoma
.... should i have used anti-seize? i didn't. i did use the dielectric grease in the boots and on the end of the wire going into the coil. should i pull them out and put some on, or just deal with it later? i didn't have a torque wrench, but i tightened them down about as much as they were when i removed them. hm. hopefully it's ok?
it wasn't that bad, i have a SOHC sport with a body lift, i'm a girl, and i just wiggled into the wheel well. didn't have to remove the wheels or anything.
the driver's side plug on toward the front SUCKED!!! too much crap on that side. passenger side was cake.
after i started it up to test em out, had a bit of a shudder at idle, but took it for a drive and it seemed to go away. they plugs they gave me at oreilly's look different then the ones i pulled out, but i think they are newer??? they were motorcraft, i'll have to look at the box to get the number. they were definitely different though. i had the neg batt cable off, installed a MAC intake last week and new catback a few days ago, so hopefully i'm not messing with too much at once!
i'll post pics of the plugs later... the pass side ones looked fine i think, the drivers side ones were a bit worse for the wear, rounded off, etc.
