Aligning and calibrating compass
XLT2002 said:
Thanks Inow need to know how to set or calibrate the compass and find out how I can remove the cigar lighter from the console, it is not working.
In Ozone Park NY you are in zone 11.
-Press and hold the MODE button until VAR appears (about 4 secs)
-Release the MODE button and the display will show current zone.
-Press the MODE button repeatedly untill you get to 11.
-After about 3 secs, the display will flash and return to normal operation.
If it still seems inaccurate, you may need to recalibrate the compass:
-Find an open area that is free of metal structures and high voltage lines like a very large empty parking lot. (I did mine in the Jones Beach parking lot at about 9pm.)
-Press and hold the MODE button until CAL appears ( about 8-9 secs).
-Once the CAL indicator appears, release the MODE butten and drive very slowly (less than 3mph) in a 360 degree circle until CAL turns itself off. May take 2-3 circles.
-Check that VAR is still at 11 and you are done.
Lastly, to get to the cigarette lighter, remove the radio and you can easily reach the wire connector for the cigarrette lighter and unscrew the unit. Mine didn't work either but when I checked, the wires were loose and pushing them firmly together has all working as expected.
