KC Daylighters | Ford Explorer Forums
KC Daylighters
baff2004
Flagstaff, Az / Nogales, Az
'95 XLT
Im buying a 2 sets of KC Daylighters :D and Im going to mount them on my safari rack. Do the lights come with enough wiring to roof mount them?:rolleyes:
probably depends on how you mount them
Should be fine, if not you can supplement with thick enough speaker wire or any stranded wire that's thick enough.
yea i just used some 2 strand lamp wire when i did mine. just something pretty heavy. dont ask the guys at home depot though cause they'll tell you you need to go to auto zone :p
Whatever you use just make sure it has plenty on insulation and is flexable. Use gromets where you are passing the wire through a drilled(bare metal) hole so that the metal doesnt rub off the insulation on the wire.
This site has a chart for wire size for long runs.
http://catalog.com/susq/other/wiring.htm
