Does it blow the fuse (almost if not) immediately, or is this an intermittent problem that happens unpredictably?
You could unplug the fuel inertia switch and measure resistance between the wire to the pump and ground. If lower than what should be caused by the pump motor itself (I don't know the exact reading there but should be a few ohms not just a couple or less) then you could unplug the fuel pump, take the same reading again, and if not low ohms, measure where that wire goes to the pump connector and ground on the connector to see if the pump itself is pulling too much current (defective from factory).
Similarly if the wire towards the pump reads good you can measure resistance between the wire to the inertia switch and ground.
