Key less entry ? | Ford Explorer Forums
Key less entry ?
77bigblock
Thorn Hill,Tn.
98 XLT
Hey all new to group. Have a ? on keyless entry system. Is there a way to reset code? just purchased my 98 explorer the hand held doesn`t work, and i changed the battery too. So i was hoping i could just reset code. Previous owner never knew the code. So i need help with this one. Thanks, :dunno:
If you are talking about the remote key fob, what you need to do is
Step 1: put the key in the ignition,
Step 2: turn it on/off 8 times (don't crank) with the final time leaving it in the on position, your door locks should cycle.
Step 3: push any button on your remote. Your locks should cycle again.
Repeat step 3 for all remotes you want programmed
Turn key off.
Your remotes will now work
If you are talking about the keypad on the door, if you carefully look in the jack comparment in the back, you will see a metal electronics box, attached to the side is a sticker with a 5 digit code, this code is the master code for your keypad and with it, you can program your own code.
See this thread for more info
Thanks for the info, I`ll check on this tomorrow when i get home. Thanks again.
no problem and welcome to the forum
Thanks for all the help, my lady had it working first thing this morning. She said worked like a charm. She said to cold to work on door keypad today, but she got the hand held going for now. Thanks again for the help. Great group glad we joined.
