Keyfob and Drivers Side Front Door | Ford Explorer Forums
skidoomxz99
Leominster, MA
2002 Eddie Bauer Explorer
I have already tried searching. I have a 02 EB Explorer and the keyfob is no longer unlocking the drivers side front door (keyfob does unlock all other doors though). The power door lock switch inside also does NOT unlock or lock the front drivers side door. You can manually lock or unlock on the door, or use the key to lock/unlock the door.
Can someone please let me know things to check?
Thank you!
-Mike
sounds like a power door lock actuator? Check fuses, wires, and worst case scenerio, you'll be replacing the actuator. I believe there are guides on here for it...
