lilminner24
- July 21, 2002
- Bonifay,Fl
- 93 XLT 2WD
I bought a keyless entry system. Ihave a 93xlt the directions they gave to me have 2lock,2unlock.I know you have to install relays on 5 wire reverse.The system came with relays on board.There is a wire coming from the module labeled polarity select ,what is this and howdo you hook it up??Also i found the lock an unlock in the kick panel,but i only found 3 instead of 4.There is supose to be 2 pink/yellow an 2pink/green wires,right??
