Keyless Entry Question? | Ford Explorer Forums
mgmgmg
Plymouth, MN
'94 LTD '10 LTD V8
2005 Lincoln Aviator Keyless Entry stop working, I had the key fob's tested to see if the RF was working and yes both key fobs work, Is it possible that the Keyless entry module went bad? Please Help!
Thanks
make sure your batteries are good in the keyfob and just try re-programming it. Check your user manual it can be done DIY.
I believe you go inside the car, unlock all the doors, put the key in the ignition and switch it to position 1 8x and then press the lock button on your fob (do this process in all key fobs since it will generate a new code)
Cool Cool lincolnshibuya, will give it a go and re-program Key Fobs. First thing I did was put in new Batteries when this started.....
Thanks
