kicker 10" L7 in jl stealthbox?? | Ford Explorer Forums
fgallo
shenandoah,pa
92 xlt
does anyone know if it will fit in a jl audio stealthbox????maybe an 8" l7???
The L7 is a square sub, the stealth box is made for a 10" round sub. Sorry I don't think it's gonna work. You could always build a custom enclosure.
Steve
i know the l7 is square but what if you cut a square hole in the box around the round one?? do you think the box is deep enough??
I do not think it will fit. You would have to do alot of modifacation to the baffle board. Even then I do not know if the box would handle it. I have had a few boxes that customer built them selfs come back because they blew apart because of the pressure in the box.
I think an 8 will, as it only needs 4.63" of depth; I don't think the 10 will unless you make yourself a spacer for the depth. This under the assumption there's enough space flat frontal space already.
