ambrosiaB
- July 29, 2013
- fort worth, tx
- 2000 Ford Explorer
there's a new sound in town. checked the oil and trans fluid.... the knocking starts upon starting the car then goes away within a few minutes. also CEL is on with codes 0304 and 1151 both of these from autozone's read vacuum leak as possibility. you know the list they give you. the third code he read off the top of his head about O2 sensor bank 1. anyway. 0304 is cylinder 4 misfire. I changed the spark plugs about a year ago but not the wires. ANYWAY the question I have is would a misfire be caused (eventually) by a vacuum leak and would the knocking from a misfire be THAT obvious?
btw I have been struggling with P1151 for a couple months but after the mechanic did an OBD II read pointed to the MAF sensor. cleaned it. CEL came back on, replaced with junk yard replacement, CEL came on within a couple hours then cleared for atleast a month. then here we are. here's the major kicker I'm BROKE so I'm just figuring out what I'm going to do when I do have money.
