i replaced my radiator,hoses,stat too,and the waterpump.i done it all chasing down this antifreeze leak .my heads were leaking too on the outside.
i done a ton of work to this 4.0 ohv .
only to find out in the end that i,m still losing antifreeze.
i didnt do the work just because....it all startd when i noticed my antifreeze was always low .
the rad looked wet on one side so i started with that and the lower hose.
i was still losing
i started looking around the block with a flashlight and noticed the green trails on both sides so i knew what was coming .head gaskets.
so 500.00 in labor 300.00 in ford gaskets and head bolts later it was done .
i thought that was the end of it .
the waterpump let go soon after that (seen the trial from the weep hole)so i had that done too.
i was still losing coolant...wtf eh?
started looking around some more ....found another trail at the timing cover ....oh man i,m so fed up by now.
so i do the timing gears,the tensioner,the guide,and of course the timing cover gasket.that should finally be it right?
well so i thought.it was soon after i started getting the misfire.i guess once i buttoned up all the leaks there was enough pressure in the system to get the leak to migrate thru a head crack and thats when the misfires started.
so after dumping well over a thousand dollars into the engine i still have a cracked head .which will cost me another 500.00 in labor and about 500.00 for some heads of ebay and a bolt kit .
so i been just changing the plug and limping it along .
then a month ago i lost reverse in the trans ......
i,m so screwed.
i found a low mile used trans for 350.00 and my mechanic will install it for 200.00 probably.
the last year been hell with this truck but i have it 8 years and put 100,000 miles or more on it in that time with little more than oil,brakes,tires, so its been a good run .
at 145,000 time has caught up with it .
i bought a car and she been sitting until i get the trans done .i still drive it when it snows (still goes forward)but other than that we take the car now .
good luck and report back what you find .hopefully you fare better than i did..lol
