Largest tire size for 96 xlt | Ford Explorer Forums
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
Hi Taeo,
Welcome to our slice of Explorer Heaven. Dead Link Removed
31X10.5 seem to be the largest one can put on a stock machine. The only disadvantage is you have to recalibrate the speedometer, which is easy enough to do, or take it to a speedo shop and have them do it. Oh you will loose a little power, but adding a K&N drop-in will give it back. The advangtage is, you get a little more ground clearance, and it looks much better with bigger meats on it. Other than that, it doesn't do a damn thing. Dead Link Removed
Happy Wheelin'
Ray L.
97 XLT 4X4 4.0L SOHC
what is the largest tire size for stock 96 xlt? what could be some negative and positive side effects of using a larger tire? anyone with experiece please post a reply.
Hi Ray..
31x10.5x15 on your 97 Explorer XLT STOCK rims?? Is that the biggest for us?
Thanks,
Steve
Proud Owner of a '97 Explorer XLT 4X4 4.0 SOHC
Hi Steve,
Yes, They are on stock rims.
Yes, that's the biggest you can fit on a stock suspension. If the Trailmaster lift doesn't work on the 95-97 models, then I might try 32X11.5 R15's, since I did the "Torsion Bar Twist" and Warrior shackles. I had plenty of room for the 31's stock, with the added inch I should be able to put the 32's on and still not bottom out in the wheel wells. I might have to do some trimming to accomidate the extra width of the tires though. Hopefully we can find a way to make the Trailmaster lift fit. Dead Link Removed
Happy Wheelin'
Ray L.
hey guys, Dragos here-one question. I`m seeing 10.50`s on 15`s, what about 245/65/17`s. will these hit anywhere?
This thread was 10 years old :) You might try starting a new thread or searching a bit as you will get a quicker reply.
