sumless
- February 13, 2007
- '94
Greetings all,
Ok long story short. I have that cronic problem of the shackles rusting
out to the point of almost failing. After reading many postings regarding this, it seemeed to be an easy task with the exception of breaking the nuts/bolts loose. Given that information, I've been hitting them up with multiple lubricants (PBRust/WD40/etc) for over a week now to help ease the pain
of removing them. Well, All went well with the exception of one bolt going
thru the frame portion of the shackle bolt. I cannot for the life of me get it to
budge. I've gotten the shackle off (rusted and desinagreated) and was able to replace one half of it.
I have two 1/4" steel bars with 9/16" holes 6" distance. I Can't remove the upper bolt going thru the frame. The bolt itself turns and the metal sleve within the rubber turns as well, but it would seem that the rubber bushing has seperated
from that item allowing it to turn. Since I cannot remove that bolt, I had
to resort to putting in only one side of the shackle. My worry is that this
may put stress on the bolts holding it if I drive or (lord forbid) tow something
to the point of failure.
AscII example:
=========|| s
Frame^ || h
|| a
|| c
=========|| kle
^Leaf Spring
Note that there is no way to place a shackle on the innerside of this
example because the frame bolt will not budge.
So my questions
Is it likely to fail in this configuration under light load (i.e. just driving around)
What steps can I try to take to remove the upper bolt?
Is there a kit/part to replace that entire rubber burshing now that it
has seperated from the sleve that supports the bolt?
Thanks in advance.
-Joe
AscII example:
=========|| s
Frame^ || h
|| a
|| c
=========|| kle
^Leaf Spring
So my questions
Thanks in advance.
-Joe
