scottboarder
- April 11, 2010
- Whistler, BC, Canada
- 2002 Ford Explorer Ltd V8
Hi,
I have discovered a leak on the driver side pillar in the top left corner to the left of the sun visor.
Above I have discovered a crack, or cracked paint on the left water channel where the channel meets the window.
Am I correct in assuming that this is where the leak could be coming from or a red herring?
Should water be allowed in from this water drain? I have read about a drainage tube getting blocked
I took it to a bodyshop but they want $500 to remove windscreen and repair the crack.
Any help appreciated
Scott
Scott
