Leaking Coolant....Help Please ASAP | Ford Explorer Forums
fire228
I have a 2006 Explorer and a few days ago it ran hot. Apparently the coolant leaked out and I didnt notice, then when driving one day I seen the Temp gauge going up and could smell the coolant. So I made it back home and sure enough it was bone dry!
I filled it up and waited a few hours and took it for a test drive and everything went fine and was back to normal.
Well since then, it leaks all the coolant out!! Its a slow drip and leaks it all out in 6-7 hours.
Attached is some pics of where its coming from. This is the only area I see it dripping and notice it wet. Its on the Drive Side of the radiator
Any Help or Suggestions???
http://img543.imageshack.us/img543/3548/leakx.jpg
Most likely the radiator, have the cooling system pressure tested. Cap OK?
Do you have a pressure tester. If you do you could fill it up. Pump up the tester to the psi on your cap. Then verify where the leak is. By your pick I would guess the radiator went. But water likes to track and could be flowing from some where else.
