Leaking moonroof problem | Ford Explorer Forums
TAKECOVER
Huntsville Al
1998 Explorer EB V8
Hello, I just purchased a 98 EB and the moonroof is leaking water down the front edge of the headliner at the windshield on the drivers side. Does anyone have any ideas as to where to start to look for a reapair? Are there drain holes anywhere that are prone to clog up maybe?
Moonroof leaks are a result of the fact that water has to go SOMEWHERE. Some water normally leaks past the moonroof gasket, but it is usually channeled away from the headliner and inside of the cabin through drains in the front and back corners of the roof. Chesk to see if these drains are clogged.
