Leaking something. Need help | Ford Explorer Forums
BigJoe1094
New Jersey
2000 Mercury Mountaineer
ok guys so while installing my front skid plate i noticed that my passenger LCA was soaked in something as well as the surrounding components. im in no way shape or form a mechanic so i really cant identify what it is but my GUESS is coolant. so can anyone confirm this? has this happened to anyone before and if so can you tell me what it is? hoping its nothing serious. heres a pic of the skid but you can see the LCA on the left. ill get better pics if needed
Could be anything - coolant, motor oil, brake fluid, oil that leaked out of a blown shock.
If it's coolant you should be able to tell by the smell.
I think I can rule out the shock. Since they are fairly new. I'll try and check if it smells like coolant today. Thanks for the response.
maybe check your fluid levels... especially the rad and overflow tank... :-)
i did check fluids. coolant was low which is why i had suspected it.....and where would th overflow tank be?
Overflow tank is right by the washer fluid reservoir. That is a nice looking skid plate too.
Coolant will leave dried green residue nearby, but you can dab your finger to it and taste it. That little bit won't hurt you. Coolant tastes sweet, have your cold drink ready to wash the taste out of your mouth afterwards. When looking for oil leaks, look for a clean oily surface. That means that that is where the freshest oil is at and that is where your oil is coming from.
Also could be power stearing fluid if that small cooler has a leak whatever it is its thin or under pressure cause its splatterin its way towards the back real good
Looks just like my 96. Seeping seal at the power steering rack.
Yea rack was my other guess also need more picks and if poss without the skidplate in the way
Check the axle seal, where the half-shaft comes out of the front axle tube...they are known to seep there a bit.
