Kjhadfield
- March 21, 2014
- Panama City Beach, FL
- 02 sport trac 4wd
Like many, that needs to do any work under the hood in the dark, wonder why it wasn't included. I'm tired of the poor lighting, the flash lights and maybe on occasions a lighter.
I have seen the 3 projects listed on mysporttrac but have a few questions for understanding.
I have purchased a 19" led strip, specs say volt range 9-14 & 1.1 watt per foot (which means @ 19" I'm looking at 2.2 watts…so does that mean my fuse should be 3amp or 5?). I also don't really want to power directly from battery for this small led (save the direct power for high power accessories, I'm thinking), so instead was thinking of the add a fuse/circuit. Thoughts? I don't know how it works but would like to tap into a empty slot that hopefully has 12 constant (my thinking on constant is I can do work with key out and lights can be on). I want to eventually put a door ajar switch or whatever they are called so I can have lights come on auto on hood up. But till I can find 1 I have a switch that I was hoping I could use, it's a 2 pole and 10 or 15 amp?
I want to make sure I have the wiring diagram right too or how I think it should be wired. The red wire from led goes to 1 prong on switch (does it matter which 1?) and attached to the same prong a wire going to the add a fuse? Do I just ground the black from LEDs and then ground the 2nd prong on the switch? The more I think about it, Something about that doesn't seem right to me…which Is why I come asking for help.
I can't wait till I actually hook these up and thanks for any help I can get
