Lift ideas | Ford Explorer Forums
Lift ideas
Rbrown849
Bohemia,Ny
99 ford explorer sport
Any ideas other then body lift to get my truck in the air
It's a 99 explorer sport sitting on 31s I have a 3 inch body lift thanx to big joe but I wanna lift the suspension as well
Well if your 2WD then go with lift spindles in the front and maybe shackles or aal in the back. It all depends on how much you are willing to spend.
If you have the mono leaf pack then swit h those out for bigger ones. Then throw some shackles on it and you've got some back lift. If you are 2wd you can crank the torsion bars up to the max. There's your front. Do a little research on these methods to double check how they work for your specific vehicle as I don't own a Sport :P
It's 4x4 I'm willing to spend the money I just keep getting dead end searches. I wanna do the suspension lift b4 the body lift to get more ground clearance
Change the leaf pack out and do a spring over axle conversion. That'll give you 4-6" in the back. Look up the Superlift 4" (I think) kit. It should work with yours I do believe. There's a sticky in one of the subforums with lift ideas. Maybe the 2nd gen modified subforum.
Thanks alot. Appreciate it
