Lift kits and brake lines??? | Ford Explorer Forums
sirhk100
las vegas
'91
I've been running with a spring over and 33" tires in the rear and at full droop like on a rack or jack stands the brake lines were tight. This weekend I put on a custom leaf pack with 5"s of lift that's mounted spring under and is made of 10 very thin leafs. I also custom fabbed up new upper shock mounts that allowed me to run 14" travel 7100 bilsteins with reservoirs. This set up made an AMAZING improvment in on highway handling and flexs great on my rocks in the yard that can lift the rear tire off the ground. Here's my question......
For those of you with lifts, how did you extend you e-brake line and regular brake line. I'm getting 14"s of verticle travel in the rear and maxing out the lines. Does anyone have any pictures of their brake line setup?
Thanks,
Khris
I don't have a picture of mine installed, but I bought these at 4wheelparts.com
would those work for 95+ ?
not that set, but you can call them and see if they have some or can get some.
