No. Well, sort of, but you can't use the 4wd knuckles which is the expensive part of the kit so there is no point in spending that much money. What you want are drop spindles for a 2wd Ranger Edge from Doestch or Fabtech and swap to Ranger brake rotors. Get the rear springs and shocks from Superlift, they will sell them separately, or see if Fabtech has them.
You can also do the same torsion twist and Warrior shackles lift or body lift that the 4x4's use.
