Do you still have your old spring pack? If you want to upgrade from the 4" (SUA) to a 5.5" (SOA) I would imagine your best bet would be to use your original spring pack. They're the ones intended to be used with that particular lift kit. 4" springs located over the axle will give you way more lift than the front. Maybe you can remove some of the leaves, but that might present a safety hazard. You might just want to keep the 4" springs in place and add longer shackles. In theory, 3" longer shackles will provide 1.5" of lift. That 1.5" of lift added to your already existing 4" leaf springs will total 5.5". Presto! Add-a-leaves are not an option! SOA's offer more ground clearance and flex but are notorious for wearing out the springs. If I still had the original springs then I would go with the SOA. If not, then the addition of longer shackles should work out fine. The choice is yours.
