- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
Hey all..
Our front springs aren't lifting the front like they used to. Currently they are James Duff 2.5" lift springs (with f-150 spacers underneath). They have at least 180k miles on them. I really like the Duff springs since they are progressive, but I am wanting to go spring over axle in the rear and the front have sagged enough that on a hard hit the front shocks bottome out (only 2" of up travle left)
As I understand it, an SOA will lift the rear about 5.5" or so and even with new Duff springs and the f-150 spacers the front is only lifted about 4".
The rear springs do need to be replaced anyway (they are OME-36 springs, 2" lift) with War-153 shackles and the springs have at least 150k miles on them.
My real question is, does anyone else (other than Duff) make a progressive rate front spring? If so, how much lift are they? (2.5", 4"?). I'm thinking of either using a new Duff front spring (2.5") with f-150 spacers and taking out the War-153 shackles and keep using our "flat" rear springs (they dont' lift much at all) Or if I have to, get a pair of rear springs made (I still have my sagged stock ones I could use just in case).
My other option is to use someone elses progressive rate front springs. If I can find a 4" progressive front spring that would make life easier with the rear but I haven't found one.
Thanks in advance for any input...
