limited slip options | Ford Explorer Forums
DEERE6030
Omaha, Ne
99 FORD RANGER XLT
what are my options for a limited slip in my 1999 Explorer 5.0 awd?
There is a good chance you already have it. If you a factory towing pkg then you most likely have it. You can get the whole rear from the junk yard. If you are looking for aftermarket parts then there a lot of threads on that in the modified section.
We all have 8.8" rear gears. You should use a second gen rear as they have thicker axles than the first gen.
look on your drivers door for the "axle code"
it's probably D4 or 3.73 gears limited slip
I found a D2 in the junk yard today or 4.10 limited slip but that would throw off my speedometer unless I lifted and upgraded the tires
You have a limited slip if you have AWD 5.0
You can calibrate the speedo.
