speed1975
- March 21, 2015
- 2004 lincoln avaitor
My 2004 Lincoln aviator has had this issue for a couple of years now and I just am not sure what the problem exactly is.
On cold startup or if it has sat for a few hours on startup there is a loud ticking/ rattle sound that comes from the engine. It does it for like 3 seconds then stops and sounds fine.
I have traced it to two possibilities.
1. Timing chain stretch and or slack tensioner. i was reading that someone said they are Hydraulic??? I was not sure.
2. Which seems more likely is the Hydraulic lifters. I was told they lose their seal and bleed off if they sit long enough? Sounds logical however I want to be 99.9% sure before I go trying to replace these guys..
also if it is lifters how much of a problem is it really... is it worth replacing them?
Any one have this or know someone who had had the same problem?
S.
S.
