liscense plate light | Ford Explorer Forums
brandonloserkid
spring hill, fl
'97 Explorer Sport
one of my liscense plate lights broke and was pushed through the bumper, i cant get it to stay set cause the tabs are broken, is anyone parting out a explorer, and has one of these? or does any one know where i can get one
As you probably already know, the Ford dealer is about your best bet. I had to replace one of mine a couple of years ago but can't for the life of me remember how much it cost. I don't remember it being too much though. After a few years, that plastic becomes brittle anyway, so if you get a used one you will probably end up breaking those tabs off eventually. IF I come across a receipt I'll post the amount.
Ken
I took the broken one to NAPA and they found a rubber type one that fit & works fine. Just push in & turn.
even if you go to ford it shouldn't be that much.
i had to get a front turn signal fixture, and it was only like 9 bucks
I think alot of people have a false impression of the dealers. My ford dealer here is actually reseaonably priced when it comes to replacement parts. I needed new windsheild wiper arms and the they were only 14 bucks apiece... I was expecting like 25-30 bucks for each. The dealership is always the best bet for new replacement parts.
if i want cheap and can wait for it to ship, i go to www.fordpartsnetwork.com <<< THEY ARE AWESOME!!!!!
if i need it right now, i try the dealer, but it usually takes them a few days to get it anyways
Broke one of mine off accidentally too, super glue took care of it. Realigned the light assembly back on the bumper and glued it. To change the bulb, reach under the back side of the bumper, twist the connection and pull out the bulb and wire. Change if burnt out, reach back under, line the prongs, push in and twist.
