Hi All,
OK so here is what I have. 1996 XLT 4dr 4X4 Auto trans 4.0L OHV with3.73 LS axle, the rig has 128 K on her.
Here is what it's doing. At 55 MPH With O/D on I'm turning 2900 rpm when I turn O/D off it goes up to 3600 RPM. Doing a search here it sounds like I have no 4th gear? So where should I look. There are no codes and the O/D light does not flash. I do have a rattle sound underneath could this also be caused by a Torque converter? The thing is @ 110,713 this truck had a transmission rebuild, I have the records. it says that " Road test Diag code po732 EEC system OK interm band broken, replace forward and direct clutches flush cooler replace Torq conv and O/H valve Body, road test all OK". on the bill there is pricing for a new Torq converter, band asy and valve asy. So it sounds like a pretty through rebuild? this work was all done at a ford garage that has a good reputation. The only catch is that this was done in 2004 and it has been driven very little since.
Now only 18k later it sounds like maybe 4th gear is out? Could that be? Wouldn't the band asy and valve body repaired the 4th gear then? Any ideas where to check? I'm not into trying to rebuild the transmission myself but I am capable of doing some checks and minor repairs. Any ideas or help would be greatly appreciated! Thank you!
