hi this is buck,, im going to address this from several diffrent directions so pls bear with me,, if u just lost your job and are hard up and u can return this part with no harm no foul then that might be the thingg to do,,,next i have looked at the master install kit and if you are not changing ring gears to a new ratio or your diff brgs are good then you do not need master install,, it has shims, brgs gaskets, everthing neeeded for complete new setup,, but if your not changing everything inside then its not needed, just a new gasket,,, you do have to pull your axles,, be careful pf the seals inside the axle tiubes if you have them, the ring gear will have to knocked off the carrier but mark the ring and carrier , put it back in exactly same spot and u will not have problems,, use a bench vise,, stay clean, pay attention to torque specs, and u will do ok,, the ring has to come off because the cross pin is under the ring and u cannot remove it without pulling ring off,,, the jeep diff in the article used a roll pin to hold the pin in and use correctly sized pin punch to get it out if your diff is the same,, use a new roll pin to reinstall,,if your dad is handy get him to help, keep every thing clean and if you are any mechanical ability at all u will do ok,,if you have kids, send it back and give the money to your wife she will use it for stuff women are good at,, macaroni an cheese and electric bills, look at this
http://www.rockcrawler.com/techreports/powertrax_tj/page2.asp this just an old man talkin,, u have a wife an kids family send it back, if u livin at home with dad jump in its good to be able to accomplish a good well palaned job,, just my two buck, have fun let us know,,,,,, ok update,, i tried it to doublechek my stuff,, i sometimes leave out stuff or add,, anyway on the site it sez page not found,, on techreport when u clik that on techreports it leaves out the ts off reports an puts in ...somethingi think if u cut and past to the google bar u will get tech reports,, buck i dont know how tho fix this one, yall can give it your best i will not be offended if u can add something that works,, buck
