Looking for 5.0 Ex/Mt - Any tips on what to look out for? | Ford Explorer Forums
airforceinfinit
Garden City, MI
None...Yet
I currently drive an '08 Mustang GT and live in SE Michigan...not a good combo during the winter. So I'm looking around for a decent 4x4/AWD year round vehicle (mostly winter) that'll also last me several years. I've decided I either want to go for a 1998-2001 V8 5.0L Explorer/Mountaineer or a 2000-2004 V8 4.7L Grand Cherokee. I'm leaning more towards the Ex/Mt since I am a Ford guy and I hear about the various issues the GC has with brakes and electrical stuff. My budget runs up to $8,000 that I can spend but I'd rather not go right up to my limit so that I have some breathing room in case something needs repair on the vehicle.
So, my questions are this:
1.) For my budget limits, what should I expect in terms of age/mileage/features? Personally I prefer the Eddie Bauer/Limited/Premier packages (I do enjoy my creature comforts) so I understand the price will be a bit higher for those but not by much. Looking around on AutoTrader/Cars.com/Craigslist shows me a barrage of vehicles ranging from 70k to 200k miles and prices ranging from $2k to $12k. Am I safe in buying one with more than 120k miles or should I look for lower?
2.) What should I look out for in terms of wear and problematic issues? I'm aware of the blend door problem and the EGR/Manifold noise issue, but are there any other common problems (major and minor) with the 5.0, 4R70W, T-case, or Ex/Mt itself?
I've test driven a few recently and found a couple around ~105k miles that ran/sounded/looked great, but one with ~75k that ran/sounded good but looked rough inside and threw a code on my test drive (!!). I don't know much mechanically so I'm not confident on looking it over without some insight. I have a mechanic friend of mine coming with me next week for a couple days to help me find one in good shape, but I'd like to know what to look out for.
Thanks in advance!
Thanks in advance!
75k and 105k is fine for a 99-01 v8 explorer ... Sounds like the guy cleared the code and tried to sell it before it came back. Find out what the code is. You might be able to get a great deal on it. In California a 99-01 limited in excellent condition would be around $5k-$6.5k. I found a 01 Limited with 100k miles for $4k...He was asking $5.5k What are they asking for these?
Tanks, good motors, good transmissions and good transfer cases.
Our 99 Eddie just turned over 200k and has aged very well, it still looks great the paint is bubbling a little on the inside lower rear doors a bit due to rust but no rust on the exterior I am happy for that.
And with good tires in the snow, virtually unstoppable as snow goers go.
I would say common problems include exhaust leaks, failed radio displays, wheel bearings, ball joints, rear wipers, door latches, door lock actuators. Some of those things are over rated. My rear wiper is cashed and the radio display goes out intermittently. Its also common for used cars to need a brake job or 2 in the coming years, many also have junk tires.
They also have very complex piece part exhaust systems (read: $$$) so you may want to avoid that as I have heard some junky sounding ones running around. My exhaust is in damn fine shape for 200k I'm very pleased with that and the heated seats make it a preferred ride for me.
We also have a 99 Jeep Grand with 193k on a 4.0 and that is also a darn fine truck, but its no V8 Eddie Exploder. I will say the Infinity stereo in the Heep is better.
Got 199K miles on my '97 and it's still going strong. The AWD is great! The off-road guys don't like AWD (cause there's no low range, I guess), but for public roads, both paved and dirt, I don't think you can beat it. The 5.0/4R70 drivetrain is practically indestructible. The heat is hot in the winter, and the A/C works better in the summer than some new cars I've ridden in.
As for problem areas with the 2nd gen's - lower front ball joints. But that's a $35 part and about 1.5 hours labor each side. They tend to rust first in the back of the rocker panels, directly ahead of the rear tires. Stick your head underneath to see what's going on - if it's got running boards, you can't see the rust from above.
Door latches/power locks also tend act up due to corrosion inside the latch, but that's a cheap fix as well. I got all 4 latches on ebay - they were salvaged from an Ex in Louisiana where cars don't get eaten by road salt.
A good choice
Like other people have stated this is a great engine and drive train combination. The major repair costs that I had start cropping up around 145,000 miles were:
CV-joint on aft portion of front driveshaft where it connects to the transfer case failed. Cost: $160 (Re-manufactured shaft from Advance).
Starter motor internal failure of some sort. Cost: $330 (Dealership replacement because it was snowing outside...).
Alternator internal failure would not provide proper voltage. Cost: $150 (Got a new battery for the hell of it add another $100).
Camshaft position sensor stator broke off inside sensor housing. Cost $60 (Re-manufactured from Advance).
Rear wiper and fog light switch broke off center console. Cost $5 (plastic epoxy to reattach).
Dashboard back lights progressively fail. Cost $10 (10 pack of #194 bulbs at Napa).
Front upper and lower ball joint boots fail and eventually cause bearing failure. Cost: $500 for both and new cam bolts (Give or take a hundred).
Driver's door handle looses spring tension. Cost $0 (Ignore).
Passenger rear interior door handle broke. Cost $0 (Ignore).
Radiator leak from plastic tank to aluminum core seal failure. Cost $160 (New from Advance).
Cruise control rubber buttons tear on steering wheel. Cost $0 (Ignore).
Resonator on tailpipe leaking. Cost $70 (Local muffler shop replaced with pipe).
Spark plugs and wires. Cost $80 (Autolite double platinum and wires from Advance).
Fuel filter and air filter because they needed it. Cost $30.
Keep in mind that all these problems occurred over the course of two years giving me ample time to fix them on a budget. One major thing to note about that is if you ever do your own maintenance you'll start to appreciate how much room there is to work around in these things. If I had to do it again I would still buy it. You just can't beat an AWD V8 with snow chains in the winter.
The one with 75k was a 2001 Explorer XLT (pretty basic). It was rough on the inside (read: trashed). Exterior was OK. Brakes/tires seemed ok. Some obvious paint repairs due to rust, especially on the bottom of the hatch. Motor/trans sounded fine and ran strong, but about halfway through a 15 mile test drive a code was thrown (it was the "Service Engine Soon" and not "Check Gages" light). The stealership was asking $8k.
The other with 102k was a 2000 Mountaineer Premier. It was immaculate inside and out (aside from minor wear/tear-it's a 2001), fully decked out, and ran great. Brakes were good but the tires looked like they only had one more season left in them. It sounded like there was a slight exhaust leak, though. The rear driver's side door wouldn't open from the inside (I checked the child safety lock-didn't help) and the front passenger door lock actuator sounded like it was ready to go. This stealership was also asking $8k.
For comparison, the wide variety of others I have found (but not driven/seen): 2001 Ex EB/106k/$8k, 2000 Mt Prem/123k/$4k, 1998 Mt/109k/<$5k, 2000 Mt Prem/90k/$7k, 1999 Ex EB/127k/$6k, and a bunch more. In fact, here's the AutoTrader list that I'm pretty much working with. Cars.com and Craigslist don't really offer as much as AT.
I planned on replacing the radio with an iPod ready unit, so that's not a big deal to me anyway. The other items are of concern to me and I do my best to see what's wrong. I really haven't got the slightest clue on how to tell if a wheel bearing or ball joint is good or bad. Again, I'm not mechanically inclined, but give me enough time and I can figure it out. (I'm an Electrical Engineer, if that explains my lack of mechanical knowledge... :cool:)
I do like the Jeep 4.0 motor...when it's in a Wrangler. I test drove a GC with a 4.0 and it felt a lot like an Explorer with its 4.0...anemic. I like power. *insert Tim Allen grunt here*
I would like to get into offroading some time in the future, but right now my fun stays on the streets. :burnout:
I got some buddies down in Louisiana. Maybe I can get some of them to visit some junkyards for me, if needed.
I do intend on doing most of the work myself, so this list does put the various issues in perspective. Given that I do about 20k miles a year and hopefully I can find one with close to/less than 100k miles, I should be in good shape for at least a year (I hope) but you never know.
/Wow, long post was long.
This one doesn't smell right I'd find another. For one thing most people average 12,000 miles a year and that means this vehicle was likely sitting around for awhile (8,300 mi/yr average). More importantly he was trying to hide an engine code.
This sounds like a decent vehicle. The character of the person that maintained the interior reflects on their driving habits, and likely a decent mechanical condition of the car. I would not pay $8,000 for it though.
For comparison, the wide variety of others I have found ...
To get the best bang for your buck I would purchase something around 110,000-120,000 miles, and for no more than $5,000-$6,000. I would personally lean more towards 120,000 and $5000. Also, if at all possible try to purchase your vehicles in the south away from the ocean. Then you avoid the issue of rust.
Buy the factory service manual the moment you buy the vehicle. No matter which one you choose. Don't even bother with the watered down Haynes/Chilton version. You can get paper hard copies or cd's from Ebay, with the hard copies being preferred. Any type of engineer can wrap his head around these things with a shop manual and some time.
I had about a year and a half of trouble free time when I got mine around 140,000 miles. Keep in mind I learned how to fix most of these things along the way so I bet you could too. Also, start a maintenance log of some kind for all the work that is done on it and record things like the date and mileage. It'll pay off in the end.
I would avoid the dealers and look for a by owner explorer with documented repairs.
Exactly what I thought. I offered them $6k. They counter offered $7k and wouldn't budge from there. I walked at that point.
Yeah, I'm interested to see the one I mentioned going for $4k. If that's in decent shape, I might just jump on that and then I'll have a decent cache for repairs/upgrades.
I have access to the Ford online dealer information system, so I have access to alllll FoMoCo workshop manuals. :D Part of the reason why I'm leaning towards Ford.
:thumbsup: I sent him an email! If he can go down on price, maybe I'll shoot for that! It'd be a shame for me to drive it in winter, being that they're kinda rare and all, but it'd be a niiiiice one to have.
Unfortunately owners selling them around here in good shape are kinda rare. I've found a couple here and there, but most of them are beat to hell.
