Looking for Climate Control Assembly replacement bulbs | Ford Explorer Forums
Lukas2009
Cologne
2007 Eddie Bauer V6
One of this bulbs is blown.
Does anyone have an idea what replacement bulb I will need?
I just had to replace one of those little things a #74 i think will work its a little bit bigger the the original. when i did it the first bulbs base broke getting it into the holder but after being a little more careful the second bulb went in and it worked. here is a tip for removing hard to remove bulb from the base go buy some 3M or gorilla mounting tape (its a clear silicone two sided) put it on the tips of needle nose pliers and use that on the bulb for a better grip.
I think you can get the complete bulb with base.
These ones are Osram/Sylvania 2721MFX.
Well my local store did not have any and I did not want to order any. But that is great to know.
