Ranger Rick
- December 18, 2002
- Rochester, NY
- '98 Mountaineer AWD
My '98 Mountaineer has several issues with the Mach audio system, which is really the truck's only weakness.
1) the power antenne no longer lowers. By the sounds of it, the drive gear is stripped, because it still tries to retract the mast when the radio powers down but only achieves making a racket.
2) the head unit display is completely out. Functionally, it works OK (aside from the CD player being skip-happy), and once I managed to program the radio station buttons, normal control through the steering wheel buttons works fine.
3) the subwoofer in the rear is blown and buzzes with really any signal to it. I've tried turning the bass way down (complicated by the lack of display on the head unit), but it still buzzes.
4) one of the rear door speakers is also blown.
So, here is what I would like to know:
A) Is the antenne power on it's own circuit that I can pull the fuse on? Or do I have to disconnect it from the radio wiring?
B) Do I need a unique harness adapter for the Mach system to put in an aftermarket head unit? I have installed many head units over the years, so this isn't new to me, but it isn't clear to me how/if the Mach system has special needs. Wiring and soldering are not a problem for me, as long as I know what I'm getting into in advance. I've heard that the stock units are prone to display problems to begin with, but I wanted a bluetooth-capable head unit anyway. However, I don't want to give up my steering wheel controls. Is there a way to retain their operation (or the rear seat controls - but that's not as important to me) with an aftermarket unit?
C) How do I remove the sub enclosure? I'm reluctant to start prying on the thing. Once I have it out, is it feasible to simply replace the subwoofer with an aftermarket piece, or would that require a bit of custom work? I'm not an audiophile - I'm not super fussy about the sound of the system - but I don't want to sound bad. At the same time, I'd be hard pressed to know difference between a decent system and an excellent one, so I'm not interested in spending more money on it than necessary.
Any help you guys can offer or suggest would be appreciated. Thanks.
