Loud squeaking noises from the front suspension. | Ford Explorer Forums
Tone51
elizabeth nj
96 xlt 4.0
hello every one i was wondering if sum 1 could help me. there is a noise coming from the front driver side shock . it stated about 3 months ago it was very loud at first and it would make this noise when i drive and turn left or right so what i did is replace front and back shocks but the noise is still there its alot less now that replaced my shocks . any info would help
1996 xlt 4.0
Could be a few things, I would check your sway bar bushings and a bad ball-joint can cause some squeaking also.
Thanks guys I really appriciate the info and help , ill be sure to check those bushings , one more thing do u think it can be the shock absorber ? I kno replaced with a new 1 , but do think it could have bin a shock defective??
its probably not the shock, mine is doing this too and i replaced my balljoints and it went away. it only does it when the truck gets wet now, i think its a lower control arm or swar bar bushing.
ok thanks for that info ill have them check out
