Low Beam Headlights out! | Ford Explorer Forums
Tray1941
Atlanta, GA
2003 Sport Trac XLT
Hello, everyone. need some help. My driver side low beam headlight was not working. High Beams work on boths sides. Bulb is fine. I ran a wire from the passenger side low beam to the drivers side low beam thinking there was a break on the low beam wire driver side. Now only the high beams work on both sides. Even after removing the wire I ran. My owners manual was stolen so I have no idea which fuses to look at. I have a 2003 Sport Trac XLT. Any help is appreciated. Even a post of the fuse box diagram would help.
Thanks, Tray:confused:
Can't really help you with the problem, but you can download an owner's manual at
Dead Link Removed
the manual should have a fuse map.
