Low beam headlights out | Ford Explorer Forums
Tray1941
Atlanta, GA
2003 Sport Trac XLT
Hello, everyone. need some help. My driver side low beam headlight was not working. High Beams work on boths sides. Bulb is fine. I ran a wire from the passenger side low beam to the drivers side low beam thinking there was a break on the low beam wire driver side. Now only the high beams work on both sides. Even after removing the wire I ran. My owners manual was stolen so I have no idea which fuses to look at. I have a 2003 Sport Trac XLT. Any help is appreciated. Even a post of the fuse box diagram would help.
Thanks, Tray:confused:
Ryan, thanks for the Welcome and the quick reply. I appreciate the fuse box info. I guess they must be different for a Sport Trac versus an explorer becuase mine certainly looks different. Any idea where I could find the info for the Sport Trac? I know it should be the same but it just isn't. Tray
Try here for an Owner's Guide: Dead Link Removed
Low beams out!
That is it exactly. Found just what I needed. Thanks, Tray:
