4EyedTurd
- June 16, 2016
- Waco,Tx
- 2005 Explorer
I finally got my sisters explorer running and it has no oil pressure at idle but does when you rev it up. After searching the oil pressure is below 5psi for the gauge to read zero and getting a lot of results of people with little or no oil pressure. So, after a new oil pump, pickup timing chains and guides this is where I am. I found evidence where the timing chains rubbed bolts and created grey/silver dust and it made it to the rod bearings. So, I'm going to drop the pan and try and roll new rod bearings into place and see if that helps.
Also, is there any other reasons why these suffer from low oil pressure?
