Kiwifrog
- January 10, 2020
- Auckland
- 2002 Explorer 4.6L V8 Ltd
Hi All,
I have a 2002 non mod Australian build v8 Limited Ford Explorer. It's done about 130,000km (80,000miles). I took it in for a service and received it back to day. Everything appears to be working fine, however I noticed that when I turn the key to the on position and leave it for a few seconds it indicates 'LOW OIL PRESSURE'. This is before I turn the engine over to start it. Once turned over the message disappears and everything appears to be working fine - and by that I mean I run a diagnostic while it's running using the Explores standard diagnostic feature and it tells me oil pressure etc is OK. I have been driving it a little and there are no signs what so ever of low oil pressure either. All gauges while the engine is running are sitting at normal position. I'm not sure I've noticed this message before - I only mention it because the mechanics mentioned it. My question is whether it's normal to see the 'LOW OIL PRESSURE' message before the engine turns over? Logic says yes, but it's somewhat sating the obvious so seems a bit odd. Thanks in advance
