George W
- March 25, 2009
- NH
- 2002 Ford Ranger Edge 4X4
No ABS lights on in the dash startup self tes showes ABS light is working... Heres the issue...
I have a slow speed ABS issue when slowing to a stop and hit about 5 MPH My ABS kicks in the peddle ratchets down and I apply more brake to get to a stop.. ABS feels like it's working as it should except comes in play at low speed for no reason dry clean paved roads bellow 5 MPH or so.. Tires all the same size and aired to 29psi , wear is even.. I just installed new front rotors and new brake pads with slides and anti rattle kit.. stil have same issue.. Bled brakes all the way around to flush the system used 1qt of Dot 3 fluid.. still same issue.. I was talking to a guy in the parts store.. said he went threw the same thing last week and it was a front ABS sensor..
Is there a way I can tell if it's the left or right front sensor? It's a 4X4 and is a real pain to install a new one just to swap it out in the other side if I didn't guess right the first time.. Cold weather is setting in and I need to do this ASAP as I'm working outside.. Thanks for your help! I have a Ford work shop manual.. I don't have a brake out box or ABS scan tool... I have a volt metter.. George
