well you need to do some testing with a meter.... instead of just replacing parts. Without testing, you don't actually know if you are chasing a voltage issue or a ground problem.
Having said that, your likely problem is your MFS switch... a few posts have found this problem in the past.... of course, it depends on the options as others have mentioned. Anyways, a meter will certainly help focus your journey.
