Wanted - Lower Intake Manifold Studs | Ford Explorer Forums
Wanted Lower Intake Manifold Studs
Parts or services wanted
davidabot007
Colorado Springs, CO
1996 XLT 4X4
I am on the look for 8 Lower Intake Manifold studs inorder to finish rebuilding my truck. My local Ford dealer states that Ford no longer makes that part. Napa, Checker/O'Rieley, and the like are not stocking this either. Has anyone out there found where I can find this part?
5.0L of 4.0L? If it's a 5.0, try Summit Racing. If it's a 4.0.... I didn't think they had lower intake manifold studs... I thought the lower IM bolted in place?
The only studs I can think of on the 4.0 ohv are the ones that hold the fuel rail and upper intake (plenum) to the lower intake.
EDIT: And I have a set of these...
~Mark
My truck is the 4.0. These studs screw into the top of the block, then the lower intake manifold gasket slips down over, followed by the lower intake manifold; the manifold is secured to the block by nuts screwing down on the studs. Yes, there are two additional studs (much smaller) for the fuel rail.
IIRC there was only 1 or 2 studs that the lower intake goes over.. The rest are bolts..
I am assuming we are talking about a 4.0 ohv here..
If so, I have a full set of nuts/bolts I took off the old motor when I took it apart (its now just a short block/ lying on the ground) and I can look at the pile and pull out the ones you need...
~Mark
~Mark
Hi Mark,
I'm looking for a Fuel Rail Stud for 1991 Ford Ranger 4.0l v6 push rod engine or ohv.
Manny
barkada@hotmail.com
