Lucas Oil Stabilizer | Ford Explorer Forums
Vozar
Murfreesboro,Tennessee
94,98 & 03 explorer
Who has used Lusas Oil Stabilizer. Did it work good or bad? I just bought a bottle and put some in my front diff. Im hoping to stop a leak from one of my seals ive had ever since i got my gears. Anyone used it in the motor. The stuff is like honey and i was wondering wouldnt that gunk up and stick to everything in your motor. I guess thats what its designed to do but has anyone had any problems with it.? Thanks, Matt
I have used the oil stabalizer, and have noticed NO difference at all.
As for the tranny additive, it works magic!!!!!!!
I had a horrible horrible slip in my transmission, and added a quart of that stuff, and havent had the problem since.
Also, their fuel treatment is pretty good too.
I've used it in my motor, trans and power steering and it helped ALOT with the trans and power steering but didnt notice anything when im put it in the motor.
What about the diffs? Doug , do u add it every oil change?How much do u add.Im thinking about doing 41/2 quarts oil and 1/2 of stabilizer. Or could u just add it every once in a while?
never actually used it in the diffs i dunno how well it'll help with worn seals, it might slow down the leak but probably wont stop it. just give it a shot wont hurt nothin.
As for oil stabilizer, your supposed to subtract a quart of your regular motor oil and add a quart (which is the bottle they sell) of the lucas. Also would be good to use as your oil, if your low a quart inbetween oil changes.
I know people who use 5 bottles of lucas when they do an oil change, and use no regular motor oil......Though I never saw any difference with adding it or not.
4 quarts of reg motor oil
1 lucas bottle.
Not sure when to add the tranny stabilizer.....I just add it whenever I get low.
For the fuel treatment, run your tank almost empty, pour a little bottle in your tank, then fill up.
