Madbutchers ****machine sas | Page 3 | Ford Explorer Forums
Can't wait to get my wheels and axle swap kit :D
I'd say those negative offset hummer wheels will help keep your tires under the Ex.
Do the H1 wheels you ordered come with the inner locks? They aren't in the picture. Like these on mine. Mine are H1 8 bolt double beadlocks that have been recentered with TrailWorthy Fab 6 lug centers to use on my Dana 44 HD from a '89 Grand Waggy.
No they don't.. i need to order the pvc inserts later. :thumbsup:
I used the ruffstuff outriggers that are pictured first.
My wheels dident make it to NJ before the boat left the docks.. but my Dana 60 axleswap kit is on the way:thumbsup:
Ok.. i'm confused:eek: :scratch:
Trying to find out if i can still use my stock front driveshaft after the sas.. and after some search here i find difrent awnsers:dunno:
If you're running a d44, you shouldn't have to lengthen the front. The pinion is bigger so when you push the axle up and lift it more, it fits great with the stock one.
You can get a custom adapter made to adapt a double cardan style driveshaft to your t-case. a company like tom woods driveshafts would be able to do all of that for you. For a SAS you're definantly going to need a custom front driveshaft, no doubt about it.
It depends. When you get to that part of the SAS, see if it fits and doesn't bind with articulation. If it does it needs to be modified. I have double cardigans front and rear.
i was hoping to just get a 3110 pinion yoke and mount it together.. :D
I could not find the BOM nr on my D44.. but to day i found some numbers on my diff cover..
Looks like this:
39015
044-9
03-01-88
Are you trying to determine the gear ratio?
Hope i can get the dana 60 pinion nut out with this :eek:
For the D44 spindle nut socket, I have had better luck with this type of design.
It allows a more solid connection that doesn't slip while applying high torque.
It's the pinion nut i need to get out. . Will get a new pinion yoke so i don't need to get ******* u joints or a new driveshaft :thumbsup:
Know the size is 1-5/16" .. Thats wery close to 34mm
My leafspring x member beginning to take form. . Bought the drawings from Neil that build SVO42 's X member . But need to calculate everything from inches to metric for the machine so it can be cut out. .
And i got the pinion nut out so i could put on my new pinion yoke:thumbsup:
I would like a set of those drawings, Please link. :)
Just curious about why you're doing a leafspring setup on a 1st Gen when you can easily do a radius arm, 3 link or long arm setup way cheaper and easier?
